Brief Description: click bond studs on wing for fuel probe signal con
had to use Dynon capacitance to voltage converter for fuel level signal; got from Aerotronics..about $35-50 each; add 1K resistor to each Will secure to wing rib with adel clamp Had trouble getting left fuel probe into wing. Looked like a blob of micro in first two holes. Fooled with that for a while until it became apparrent that the blobs were grease!!! Both probes inserted and click binds set
