Brief Description: called out screws too long; will use shorter ones
parts list calls out MS24693-28's to fasten the trim tab hinge to the rudder. These are very long and cause some binding on the foam. -26's will work better.....2 threads exposed...will chekc 43-13 to verify that this is correct. -27 would work best...don't have any, not sure they are een available
-28 on left, -26 on right
close up of -28
close up of -26; 2 threads exposed through nutplate
