Brief Description: test fit taillight...need to grind screw heads; mo
6-32 x 3/4" machine screws will work, but will need to grind heads down a bit to clear trim plate of taillight metal mounting plate will need to be moved in a bit; will try to release it with heat gun tomorrow, and re-flox. Off about 1/8" because I lined it up on the mold edge, which was off to centerline.
