Brief Description: rought cut rudder pushrods, flox rod ends; figure
rivets for push rods should be 1/8" hard doem rivets. Per 43-13, rivet should prtrude 1.5 times the diameter of the rivet.....so 1/8" rivet s/b 3/16 past.
Have 10 - D10 rivets, that is 10/16...need 11/16. Next size up that I have is D12....12/16...too long. Could grind down, but only have 4 of these and need 8
Will get from Spruce or Lancair. Shouldn't need to be fooling with this. $3.74 for 1/4 pound at AS&S...about 180 rivets! Looks like D11's do not exist. Go with 12's and grind down
