Brief Description: Plan antenna; refit HS, add 2 shims to right side
Plan AAE antenna to left side VS; 43" by 1" should be OK; roughed up position; refit HS after adding shims; need to add 2 more shims to left side; trim and sand down #3 shim on left side; the phenolic. .30 s/b .25" Review Schroeder ES pics of antennae
