N144GP Lancair Super ES
Lancair Super ES
Vert Stab - Rudder
1-24-2011
rudder travel set up
check rudder travel; only about 25 degrees on right side...s/b 30.
Had to open up middle and upper hinge access holes as they were binding on the hinge at full travel.
Also had to fiddle with length of both rods trying to strike a happy balance between the sides.
30 degrees both sides now at full deflection
middle access hole before opening up
after
top hinge access hole
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
