Brief Description: trim and fit fairings; add access holes
trim both wheel pants; grind excess flox off of wheel pant releases drill 1 1/4" access holes in each pant....like Cessna 350 I saw at OSH...other builders have added round panels with screws and others have added hinged access doors.....this holes seems liek a simple, clean solution. Can add 200 MPH tape over hole if desired.
left side with air chuck shown
easy access; may need needle nose pliers ot remove valve cap
