Brief Description: Is this "cant" on the camber correct?
E-mailed Justin Hawkins at Lancair. He said to check toe-in (which I had planned to do next weekend when I was fresh) and see how it looked, also implied the once the weight of fuse top and engine were on that the wheels would be straighter? "we'll see" is what he said. Also seemed to imply (or at least silent on the issue) that there is not a designed camber in the wheel alignment. Not sure I buy it, althought the brackets appear to be squarely installed in fuselage (FB kit). Will put out some feelers to other ES builders to see what their experience was at this point in the construction. Would hate to have to move the gear attach brackets ater all the fairing work is done.
