Brief Description: safety wiring brake bracket AN5 drilled head bolts
not as tricky or difficult as I thought it might be. Referred to FAA 43-13 for specs and how to wire. Just need to visualize how the bolt would move if working loose and wire against that movement.
.041 wire used. The stuff is sharp...left some blood as evidence.
