Brief Description: re-safety prop and engine mount bolts
redid 6 prop bolts with .041 safety wire.. this time in pairs. came out a lot better than the single strand I did originally.
Redid all 4 engine mount wires...one was backwards, one sloppy, one loose, one the adel could slide if the rubber wore....moved tight up against front mount gusset. Items Dick Duncan suggested I do. Done.
