Brief Description: install rest of skybolts including studs
Angie helped me put fuselage top back on so I could fit cowl back on and install skybolt camlocs Put lower cowl back on fabricate skybolt adjusting tool...used small phillips jeweler screwdriver and ground it down to a thin sharp point used to open receptacle locking latch grind notch in outer panel as needed to have access to lock with new tool set top cowl receptacles with a piece of scrap to start
