Brief Description: continue cowl fitting and cutting
Wasn't happy with the alignment at the spinner... too far left and too high, although cowl fit well to the fuselage at this point.
added C clamps and clecos to nose inlet to hold in proper position; removed orig. clecos from fuselage joggle; shifted whole cowling as one piece to get proper alignment at spinner.
Compromise several measurments to get a solution that is OK all around
