Brief Description: figure brake fittings and connect brake lines
Matco PVPV-D parking brake valve AN816-4D nipples for out flow (NPT to flare) AN-911-1D nipples for in flow (NPT to NPT) add neoprene washers to base for each bolt loctite 592 on the non-flare fittings
