Brief Description: place and drill hole for tail tie down ring
positioned tail ring weldment to aft side of FS 237.5. Drilled 5/8" hole in fuselage bottom with a uni-bit after finding the centerline. Super glued a released taped piece of glass to bottom to support weldment in hole until flox sets.
Flox weldment in place and add 4 BID.
Wil need some minor filing and a little filller to finish off...all in all pretty good, easy, but took a lot longer that I thought it would!
