Brief Description: figure out where to put NACA fresh air scoop
figure where to place NACA scoop in forward fuselage (fresh air vents).
Bought a NACA scoop from Wicks. Had to apply heat gun to bend it slightly down to get right clearance at feet under panel. Worked out well... 45 degrees down to about 10 degrees
