Brief Description: figure and grind hole for elevator push rod to VS
figure how far down the elev. hinge center point is; 3" from center HS hinge hole to rod end hole HS hinge is 1.5" to center. Measured string to 4.5" below where HS would sit. That was meant to be 3 + 1.5". As I type this, I think it should have been 3 MINUS 1.5" May need to grind hole taller. Will check next week Ground hole to 2" diamter per manual for the 1.375" tube Tested hole clearance through range of elevator travel
used string to figure path for tube
elev hinge hole is 3" below HS, and hinge in stab is 1.5" below center
making sure tube will clear rudder bellcrank platform
