Brief Description: add 6 click-bond studs to hold fuel lines
these click-bonds are very cool. Easy to work with and finish nicely. Pricey... about $4 a piece I think, but sure beats making the phenolic block etc. Epoxy turns green when cured...very fast 5-7 minute working time. 6 studs in a pack with only one epoxy packet, so you have to use all sic at once. Gonna order another set...will sure to need them for cables, etc.
Need to get some #10 and #12 adel clamps. #8s work good for return line but need a bigger clamp for supply line. Will check hangar or roder some.
