Brief Description: info on fuel return line and fittings
Do more research on fuel system. Turns out fuel return fitting called out in the manual was already installed under the firewall forward package, albeit in a different place, and with a different fitting part #, than called out in the manual. This will save drilling and decoring the firewall separately. Will likley flip the fitting around so that the 90 degree end is inboard and the straight part to the engine. I think this will make the running of the 1/4" alum. return lines a bit cleaning and easier.
pre-installed fuel line return fitting...will flip around
bottom hole is the engine mount, black dot is where manual says to put return fitting
