Brief Description: fabricated and installed alum. brake lines
used $5 1/4" tubing bender from Advance Auto...worked OK but would have been easier to wait for the nice one I ordered from ACS...this one is indexed so you know where to bend....I had to guess. Also, does 4 different tubing sizes. Ended up redoing the left side line as the 1st bend attempt left me about 3 inches high going across the fuselage.... too much interference with boltys, etc.
down right side, through side support (will add grommets next week)
to right fitting, and across to left side
will add some poly hose to cushion lines form each other and potential rubbing on bolts
