Brief Description: torque flap tube and support bolts
AN3 to 20#-inch, AN4 to 50#-inch; applied orange torque seal to all nuts that have been torqued
Inside left support is tight causing some additional friction...was OK until torquing the bottom 2 bolts on this support. Will try to shim out the bottom to fine tune the alignment of this support
