Brief Description: seats & panels out; misc. fine tune items
adjusted sensitivity on beeper box to try to eliminate the many false start signals CCW is decrease sensitivity
change VP devices to have strobes come on at "start" phase
take front seats and panels off to check on various items
replace grommet for wires to wing root in front left; RTV wires
troubleshoot a small amount of brake fluid that was laying on co-pilot floor today...looked at it real close, wipe everything down; actuated brakes and parking brake multiple times to try to see a leak, No leak noted...I am assuming it is residual fluid from the messy parking brake changeover 2 weeks ago. Left a paper towel under the valve and panels off. Will check next time to see if there is any additional seepage.
Adjust parking brake cable so that cable does not leave the housing on panel when brake is pulled full on. Angles for brake open and brake closed look good. Prob 45 degrees each and need 17.5 per instruction sheet
