2 threads showing on bottom two and middle engine mount bolts....2 threads showing, so they are NOT shouldered out.
Did not check top two engine mount bolts as the glareshield had been installed...assumed OK.
Have 6, 7/16" flat area washers to shim mount out if needed... about 1/8" thick. Might need to add a bolt 1/8" longer is I do it. Will do one bolt at a time if needed...shouldn't be do hard.
