adjusted elev. push tubes to get proper range of motion and set sticks to vertical. Made sure that I had enough threads in each of the rods. Final adjustments can be made through the furthest aft rod end in the tail at the rudder.
Tomorrow I will check all the washers on all the rod end fittings, and set jam nuts.
