Brief Description: flox release was not good...will redo; grind and m
not enough flox for flox release on aft seat bottom; (epoxy pump was empty...thought I had enough....not!) Ground some roughness on flox...will re-do this weekend.
clearance holes for aft seat back marked
ground out to 5/8", micro'd
cured; will grind out enough for clearance for rivnuts on seat back
