Brief Description: reverse rudder cables; turnbuckles to rear
Manual contradicts itself on this....decided that I had more room to fool with adjustment of turnbuckle with them at the rear with the bellcrank. Pulled cables and reversed them after a lot of head scratching and reviewing 3 or 4 different manual sections and supplements, and checking all the available parts.
Had to true up end of right side cable....can't cut with hand tools, hand to use a metal blade in the dremel with cable in the vise
