Brief Description: figure out static port and pull parts; bend pitot
no way pitot tube was going to fit inside the wing; had to bend tube on pitot over 90 degrees..now should fit.
No VSI on this aircraft....will delete one static connection. Still need 2... airspeed and altimeter. Pitot will run to airspeed from right wing.
Pitot head does not fit inside fitting installed in wing during fastbuild. Will try to grind out inside next session. It is close.... I think grinding will do it.
