Brief Description: misc. including figuring firewall connectors
trim panel mount brackets, add tube for brake lines through firewall spar; pull release tape off of door and door opening; figure out pass through connecotrs SHC-1010 on firewall...have 11 total and can accoutn for needing six....Throttle, Prop, Mixture, ram air, oil cooler door, heat...what are the rest 4. Will attempt to ask Justin and see what I get.
