Brief Description: turn fuse; stow left wing; clean shop; fill pump
Phil help me remove the left wing. We then lowered the fuselage down and rotated it 90 degrees...across the garage. Could have used 1, maybe 2 more helpers. This is in prep for fitting stabilazer and rudder/tail. Took the oppty. to vacumn the whole garage...long past due. Refilled epoxy pump. Did more research with the ES gang regarding attaching the fuel selector fascia plate. Strained my back a bit, hopefully not too bad.
looking in; 60 degrees today!
stabilizer is 13"+ long...needed to turn sideays to have enough room to install
