Brief Description: rearrange shop; cut hole in garage wall
cut hole in SE wall of garage to facilitate putting both wings at same time.
Mikey help and rewired a receptacle that was in the way.
Will pick up 2 sheets of OSB next trip and close this up more permanently. Now, the inside is closed with plywood left over from compressor and the outside is covered by a double tarp.
