Brief Description: moved parts around...right to left
With Lynn's help, re-installed right wing to measure and cut aileron push tube to internal bell crank.
Then moved right wing outside, moved fuselage outside, took down left wing fron wall. Rotated fuselage 180 degrees and put back in garage. Put right wing back, but just laid it against the wall rather than hanging it...need more help to get it up. Might just leave it leaning there.
Bring left wing in and finally got it mated up; just didn;t want to go. Will do all the left side steps that I just completed on the right side.
left wing now on
ready to work on left side aileron tubes and fairings
