set up epoxy pump and tested ratio and hardness; ratio was 11 grams hardener to 46 grams resin = .2391....should be .26. Close enough I figure. Hardness good. Set up in about 20 minutes. Hard. Also leveled fusealge with rotary laser, readjusted cradles
laser on forward dimple...can't see with lights on
turned lights off to show up laser beam in photo
Dead nuts; adjusted rear cradle with new bolt holes
