Jacked each side separately and checked operation of brakes and parking brake. Operate correctly.
Engine run. Check cowl for rub... minor 1" rub at 8 o'clock. Will keep an eye on. Right now I think I would sand it down rather than add washers. Or, consider adding washers to two bottom mount bolts only.
Top gap looks good.
Engine ran well. Got some VP "engine" warnings....fuel flow and/or fuel pressure, I think.. Will research further and either move alarm points out, or disable the alarm. Probably the former.
