Brief Description: rechecked HS to cradle; e-mailed pics to Lancair
Justin, following up on my HS cradle shimming issue from last week in case you are interested.
Rechecked the HS in the cradle today. Incidence set to -.3 degrees, all level and square.. LE to HS appears to be at front of cradle. Gap on left side is more than right side, but still a pretty good gap….chord of HS does not match the cradle strip.
I will hysol/flox it in place, and add 2 BIDs as called for.
