rechecked incidence anlge for HS. Manual calls for -.05 degrees. It was et at -.6 as "close enough"....where I had originally set it. Consensus in ES group is that -.2 or so is better and the manual is too much forward, down. Figure I needed a shim to get it closer to -.2. Shim thicknes is .082" placed at LE of HD cradle. That gets me to .3 degrees....flox should increase that a tad. Fish wires (mason string to pull through) through rudder conduits
