Brief Description: add'l and final fitting of aileron into wing pocke
After 2 BID in wing pockets for aileron set up overnight, returned to fitting and assuring proper aileron travel.
On left side had to bend about 4 inches of the lead weight over slightly to provide enough clearance in the down position. Left side now up 21 degrees and down 13/14 degrees
On right side had to trim 1 corner at middle attach point; about 1/4". No bending required. Up 26 degrees, down 13.9 degrees. OK
left aileorn done; have proper travel in wing pocket
