Brief Description: fit left aileron with weights attached
only get 8 up and 17 down (25 degree spread in total; s/b up 13 and down 20, total 33). Fooled with that for a while, removed weight from left aileron....now up 10 and down 25.
Will take off 2nd weight layer and see if that works, then will decore inside of aileron pocket in wing (per manual) if more clearance is needed; then may need to trim depth of weight, which will entail adding more weight womewhere else on the LE of he aileron
left aileorn on to check travel with weights now installed
