Brief Description: research and prep for aileron balancing
ground holes for servo rod and control wires; need to figure out how to run wires to wing tip...through aileron or on trailing edge? Leaning towards running some nynaflow tubing as a conduit on the trailing edge, bottom side. Located old piece fo angle iron to use to hang ailerons for balancing.
Servo goes in left aileron. Trim tab installed upside down from factory. Cut safety wire and flipped over. Need to redrill 2 #57 holes for .040 safety wire on each end.
