A lot of head scratching time. Pulled plate I made to cover the two ALT CBs at top, that Aerotronics put in by mistake. (already have ANL fuses on those circuits). Remade the plate twice and painted. I am using the L (from the front) old ALT breaker hole for the new 3A CB for speed brakes. Precise Flight includes the CB in the kit. Remade plate that will cover R side hole.
Pull R side G3X to get access to run the power wire to the buss and the new breaker.
Going to be tough working back there, but do-able, but will that save for a day when I am fresh. Would be a good idea to provide access to CB panel that you can actually get to.
RTV applied to holes I added to run cables.
Marked placement of SB switch and 24V green LED annuciator light.
