Brief Description: speed brakes - pull L and R wing wires
Yup, 2.25 hours. A simple task that was hard to do. Got it done. Ultimately used fish tape to pull from wing pocket to flap access panel, drilled holes in wing root web and inner fuselage. 3/8" hole; will seal up with silicone when done. Manually fed cable from flap access area in through wing root web then through fuselage. Right above flap torque tube (~6"). Had tried previous permutations of which way to pull...couldn't do it in one shot due to minor alignment issues and a tight space to work in.
Will try to remember to get pics of wirnig in flap access panel area tomorrow
