Re.-connected batteries Tested 1 circuit at a time by engaging CB and then switch to turn on. Mostly good, but several issues to check out:
High Boost is inop; Low is OK co-pilot flap switch on grip inop. Pilot side and switch on panel are good Pitot heat inop Did NOT engage Alt's, ELT, Transponder
Will check the obvious items and contact Aerotronics as needed
