Brief Description: move ground block to a different, more accessible
Moved ground block to a more accessible location.
Re-fab 6g cable to attach panel grounds block to main ground cable/block
Added some RTV to hold it firmly in place, as I did on the original block. Will let it set up and then check it. RTV is always messy!
Main ground stud was too short, otherwise I would have attached right there. Ground block on fuselage wall is next best place. 12-14" away and connected to the main 2g ground cable.
