T-P-M cables back in; heat, defrost, oil cooler and alr air cables back in re-installed parking brake....cable run tight... had to make up some add'l length. Must have been routed differently originally reworked main two rails that support throttle quadrant decided to add two rails... one the each side of the panel.. to stiffen it up...to be fabbed pilot side air vent hose, defroster hose installed wire up 12v converter Can't get connector on to dimmer module in location I installed it at... not enough clearance to SL 30 tray... remove dimmer box to reposition. Pain in the Ass! Will mount to old rails on pilot side to be installed tomorrow Mess with connecting co-pilot side vent hose. Just can't get it. Not much room to work back there.
Bought a 1/4" Milwaukee Lithium Battery cordless rachet 2 weeks ago. Amazing, and made so much of this so much easier. Amazon... ~$150. Should have bought years ago
TPM cables back in; heat, defrost, oil cooler and alr air cables back in
reinstalled 2 main rails; cables are still spaghetti
