Brief Description: wig-wag wiring to P-1, pin 14; pull some old VP wi
Pretty difficult, and multiple terminals on that post, to get to the battery contactor post that had the main VP power 18g control wire on it. Pulled most of it out then cut, capped and shrink wrapped remaining lead. Labeled it as well in case it is needed for something else in the future.
added wig wag control wire to P-1 #14
pulled some old VP wire out
capped end that went to hot battery; shrink wrapped
