N144GP Lancair Super ES
Lancair Super ES
Garmin 3X Touch pane
6-19-2017
wire up oil temp, fuel psi, oil psi, map, adels le
Work day cut short by Tornado warnings. Packed up and heading home towards clearer skies.
Oil & Fuel PSA and MAP sensors:
Red = White 18g to 22 g +5v Pin B
Green = wh/or Signal out Pin C
Black = wh/bl Ground Pin A
Butt spiced and shrink tubed
Sensor wire plug, unplugs for sensor
oil temp wired up
manifold sensor wired up
MAP, OIl PSI, Fuel PSI
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
