Brief Description: Pull AFS sensors and VP200 CU unit
Pulled VP 200 CU... took some doing. Cut off connectors that were hard wired to other locations to re-use connectors (for buyer)
Pulled AFS CrossBow magnetometer, Oil temp, OIl Pressure, Fuel Pressure, MAP, EGT, CHT sensors/probes, crossover cabling, EGT/CHT harnesses (in tact with spade connectors on). Still need to get ARINC out; need to get some other stuff out of the way or, perhaps pull the panel blank out to get to it.
