Brief Description: final prep left lwr wing; 2 coats WLS primer
final sanding of entire lower side of left wing; sand, vac, acetone used a roller this time for the primer....16 oz. of filler base, 4 oz of catalyst, 25% reducer. The 16/4 was right on....could have used just a bit less MEK reducer rolled on with a 3/8" roller...had some fuzzies come off....wil try to find the foam rollers everyone talks about. Used a high quality roller cover for coat #2...same result. Not real bad, just some fuzz here and there. About 1 - 1 1/4 hours time between coats. Cranked heat to 70 and put the halogen lights on. Cold and rainy today...36. Supposed to head to FL tomorrow..we'll see icing at 7000 the whole way down to southern GA. Added red, high temp RTV as filler to extra area decored for remote oil filter in error a few weeks ago
