N144GP Lancair Super ES
Lancair Super ES
prepare mounting plate for fuel selector
3X3 1/4" phenolic, drill four #12 holes and countersunk to accept screws. Grind a flat edge on each screw. Flox to fuselage.
Used selector ring with release tape applied to set screws in correct position. Will add 2 BID over the top tomorrow after flox sets.
floxed in place; use selctor ring as jig to hold screws in correct position
actual fuel selector in background
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
