Was hopeful to get the AP can bus hi/lo splced into this connector goes to PFD. Planned on re-installing G3Xs and powering up to check trim operation before config-ing AP. I guess the man-handling of this wring harness casued the BL/WH wire to pin 45 to break off. Need to order Dsub crimper and extraction tool to fix this. Attached pin connectors to other wires
