N144GP Lancair Super ES
Lancair Super ES
wire up oil temp, fuel psi, oil psi, map, adels le
Work day cut short by Tornado warnings. Packed up and heading home towards clearer skies.
Oil & Fuel PSA and MAP sensors:
Red = White 18g to 22 g +5v Pin B
Green = wh/or Signal out Pin C
Black = wh/bl Ground Pin A
Butt spiced and shrink tubed
Sensor wire plug, unplugs for sensor
oil temp wired up
manifold sensor wired up
MAP, OIl PSI, Fuel PSI
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
