N144GP Lancair Super ES
Lancair Super ES
work on nose gear repair
Decided to go with a AN-4 bolt and a stack of washers instead of the phenolic. Superglued 6 fender washers together...will flox into inside of nose pant and BID over top.
Redrilled and tapped hole in nose fork to 1/4-28
large washers super-glued together
O/S will be AN4 bolt head and 1 washer
re-drilled and tapped hole to 1/4" fine
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
